Hey guys I can't seem to find where to top up the fluid for our transmission. I have an 87 SR5 6speed.
Most cars I've worked on have a filler stick right in the engine bay. Right now I'm in the middle of replacing my drivers side cv axel, and she has leaked quite a bit of fluid (axle out over night... part store gave me the wrong axle )
there are two places to "TOP OFF"
one is just above and aft of driver side axle
its a 24mm plug and a socket is required
the other is on passenger side of tranny and is a bit hard to get to
exhaust pipe is close by
its about 12" aft of the first tranny/exhaust mount clamp
use a 24mm or 15/16" boxend wrench
the proper way to fill a empty tranny is thru the hard to get drivers side hole
and you have to loosen the 19mm bolt on the bottom right of the tranny 8 full turns
and remove the front plug for a vent and when fluid comes out this hole you know its full
make sure car is level
Did you change the axle-to-case seal? If it keeps leaking - and before you buy one - see the part number and PHOTO in the OE and
Part Info Forum.
And - remove the filler plugs before the drain plugs...These are soft metal and many are rounded off. Be cautious using a non-modified socket or boxend with chamfers.
"Oh, do not ask, 'What is it?' Let us go and make our visit." T.S. Eliot - "The Love Song of J. Alfred Prufrock"
"Now and then we had a hope that, if we lived and were good, God would permit us to be pirates." Mark Twain
There is no dip stick on manual transmissions, they use the filler hole as the correct "level". The easiest way to fill the trans is to jack up the front left side (so the front filler plug is "high"), pull the filler plug on the left side of the front diff (just aft of the CV axles), and use a long clear hose to fill from the engine compartment. Fill it slowly, when it is full it will drip out of the hole. All of the three transaxle compartments are interconnected and will fill from any hole, but it will be slow because the openings are not very large.
While you are at it you should drain all the old gear oil and put fresh 90w gear oil in it. You want to take good care of the trans with frequent gear oil changes, these trannys are hard to find and costly, they have not made any in over 20 years. Use the above method, make sure 4.2 quarts goes in, that way you know it is filled.
I am thinking of making some fittings to replace the front diff filler plug to install a trans dip stick and filler tube, it would make oil changes and top ups much easier. it would come up at the fire wall and be mounted next to the distributor on the fire wall.
