I wanted to move the car with out starting it
so i reached for the shifter and popped it out of reverse into neutral without pushing in the clutch.
I pushed the car a few feet and left it.
later i loaded up the dog to take him for a hike
started the car and tried to shift into reverse but it would not go
tried all the other gears too
still no luck
it is stuck in fourth or fifth gear and the shifter flops around like its in neutral
i pulled the shifter just in case it was something simple (like the shifter itself)
but that was not it
I think my tranny went tonite
Re: I think my tranny went tonite
I think it had nothing to do with the clutch, the shifter forks get worn to the point where they will jump their track and the lever becomes useless. I had one that got stuck in 2nd gear when I was way up in Concrete WA, just did a normal shift and boom, all I got was 2nd gear. I drove it home that way, some 40 miles keeping it below 30 mph. When I pulled the drain plug out came only about a quart of gear oil full of sparkly metal particles.
Pulled the tranny this morning
took 2-1/2 hours working alone
will be installing the tranny I got from Petros a while back
9 hours total with no help and the new tranny works
only drove a mile
so more testing tomorrow
replaced axle seals and driveline seal also
only drove a mile
That trans came from Tercel4wdrules and he said it sometimes pops out of gear. You might try fluid flush (50/50 AFT/gear oil) drive it for a day and than drain, and add new gear oil. Sometimes that will clean out old gunk and metal wear and make it act properly again.
it was not the tranny i just picked up from carlos
it was the one i bought from you a year or two ago
- My tercel:: None
I didn't think so either. Besides, that trans that I gave back to xirdneh, it didn't pop out of gear, it was just annoying noisy...
2015 Honda Fit EX "Malachi"
- My tercel:: 1983 4wd Wagon
Awesome. Know I know what happened to my last trans. Now I can tear it apart and fix it so Ill have an extra. Nice!Petros wrote:I think it had nothing to do with the clutch, the shifter forks get worn to the point where they will jump their track and the lever becomes useless.
xirdneh wrote:Petros
Than that should be good trans, it had well under 200k miles on it if I recall. I rescued it from a wrecked Tercel4wd at the wrecking yard before it went to the crusher. Even if good Tercel bodies end up in the wrecking yards, no good 4wd trans should ever be allowed get sent to the crusher!
You should have it in and drivable by now, how is the new trans? The old one should be good for parts.
have not driven more than 10 miles on it
but so far so good
been out of town
but so far so good
been out of town
