putting front struts on
unknown
My tercel:: 1986
Post by unknown »
i have found a replacment strut for my t4wd the problem i cant seem to line up the bottom bolt to the sterring knuckle the first one goes in sweet but having probs with lining the 2nd up any ideas thakns guys
Re: putting front struts on
it should line up fine if you have the first bolt in. where did you get your struts? could be the wrong ones.
I put a large pry bar through the sway bar and under the lateral strut and step on it to get the lower holes to line up. Having another person do that for you is a big help.
keith
Post by keith »
You put the bottom bolt in first. Make sure the concentric washer is installed in the upper hole before you start. Then you just move the top of the steering knuckle in or out as needed for the upper bolt.
