I replaced the sway bar, refitted with a good pair of used bushings; rockauto don't have any sway to control bushings neither do alot of other places as i guess you all know
I also ended up lifting the front. The car drives pretty good, it doesn't pull either way, the steering wheel is a bit crooked, i think because i messed with the axe so much.
There is a problem though, i can feel and hear a small knocking noise from the front passenger wheel. Starts at about 25mph or so, and is hard to hear.
I was wondering if this could be a bad strut? when i inspected the strut, after compressing the strut, it didn't decompress like the other one. Is this a sign that it's bad?
But I don't think it's the strut though because the sound is not heard when im cruising in neutral.
I think it might be coming from the outer shaft joint, the ball one closer to the tire might be not great.
Do you guys think lifting adds too much extra stress on the shaft because of the increased angle?? Will the joints go bad faster now?? Unless i reduce that angle by dropping the engine a bit?
Also, i need to adjust my camber now, i figured out how to do it, with the adjusting washer but i'm just not sure if i want a proper wheel angle or do i want a bit positive camber but then the shaft angle is not as high.
Hey guys,
As the title suggests; sway bar broke, right where it connects to the control arm bushing. Weird, i didn't know sway bars could break
This all happened while i was driving so the cv boot split and its time to take apart the drive shaft....awesome
Any tricks you guys know or good-to-know info before doing such a job??
I'm thinking about getting a sway bar from the junk yard instead of paying $110 for a new one. Anybody think this is a bad idea?
While i'm at it what should i inspect/replace besides the bushings?
I'm also thinking about lifting the car using pathfinder/camry springs and thunderbird shocks. If i do the lift will it cause problems down the road if i just lift it without doing anything else??
