EGR Delete? Pros & Cons
copenhagenfiend
My tercel:: 1986 SR5 4WD
Post by copenhagenfiend »
Instead of cleaning my full egr system out through soaking and drilling and poking - can I just remove it altogether? A block off plate wouldn't be a problem for the intake side, but what to do for the 19mm bolt side? Are there any benefits to removing it? I just finished rebuliding the carb and removing the exhaust/intake manifolds to replace that gasket. My entire EGR system is carboned up like many of you have seen! And thanks from a long time creeper and first time poster!
http://www.cardomain.com/ride/3921818/1986-toyota-
*1986 Toyota Tercel SR5* again!
1999 Toyota 4Runner SR5
1990 Jeep Wrangler
http://s164.photobucket.com/albums/u11/ ... cel%204WD/
Re: EGR Delete? Pros & Cons
Welcome to the Club!
Check out this link on the plug size for the manifold: http://www.tercel4wd.com/forums/viewtop ... olt#p41490
I did this when I did the Weber and it's worked just fine.
