Anyone know where to find a good set of wiring diagrams for the Terc?
This fumbling fool knows zip about puters and web sites and all related matters...
Thanks for your help, Guy
Wiring diagrams
I just purchased the chilton or whatever from the local walmart. Seems to have good diagrams of electrical and vacuum etc etc etc.
Altho....having said that, i'm sure someone on here has a better source!
The Toyota Factory Repair Manual (800pages) has the best info and wiring diagrams you could possibly get for this car (because it's written by Toyota for Toyota Mechanics).Pegger wrote: Anyone know where to find a good set of wiring diagrams for the Terc?
Go to <a href='http://www.tercel4wd.com' target='_blank'>http://www.tercel4wd.com</a> and click on 'Technical Info'. Then click where it says 'click here to download...' and the manual will begin downloading. It'll take a long time because it is a pretty large download. If you are on a cable modem it'll probably take 20min-1hr. If you are on dial up it'll take much longer. Just leave your computer and check it when you wake up or something. Make sure you have Adobe Acrobat Reader installed on your computer.
Post here if you have questions and we'll help out.
Current:
91 LJ78 Landcruiser EX5
95 A32 Maxima SE
Former:
87 AW11 MR2 Smallport 4AGZE
93 Taurus SHO ATX
86 AL25 SR5 6spd 4wd
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
