clutch bleeding
steen
My tercel:: 1986 SR5 no mods
clutch bleeding
Post by steen »
Is there a seperate bleeder valve for the clutch? My third gear glitches every shift up or down unless I pump the clutch 3 or 4 times no matter the speed I'm going. The brake and clutch master cylinders are the same, yes? Thanks for any input, Steen
rer233
My tercel:: Multiple
Re: clutch bleeding
Post by rer233 »
there's no bleeding procedure, because the clutch is cable- activated. if you're only experiencing a problem when shifting into one gear, it's probably a trans issue. could also be a problem with the plastic sector gear on the clutch pedal, but that's unlikely.
Re: clutch bleeding
Possibly - and that's a distant possibly - the bushing at the base of the shift lever in the trans extension is worn/missing. I'd check it - there are a number of threads on this in the Repair Guides and Parts sections.
