'87 Tercel SR5 4WD Wagon in Milwaukee area
olga19
My tercel:: 1987 Toyota Tercel SR5 4WD Wagon
Post by olga19 »
It has a crack in chassis near the drivers side control arm. 3AC engine runs great 176xxx miles with alot of life left! oil changed every 2000 miles. recently rebuilt 6 speed transmission shifts great and 4wd works. front qtrpanels are torn up a bit but they still retain basic shape and strength :) Interior is in good condition w/ no rips or tears. Power sunroof works and has never leaked! comes with late 90s sony aftermarket cd/stereo. has custom stainless steel exhaust from downpipe back w/o cat. comes with an extra set of wheels and an '83 transmission. Also comes with original 1987 owners manual.
$600 obo
(note: inclometer not included)
toughtercel
Re: '87 Tercel SR5 4WD Wagon in Milwaukee area
Post by toughtercel »
this car should sell same price as scrap metal cost.
i'd say that's more than a crack, and honestly wouldn't let anyone drive it away because it's really not safe to have that on the road. sorry to be a downer, olga19.
You might as well state up front that you are selling it as a parts car...probably not easily fixable...unless someone was a REAL pro welder. Has a good engine and trans...together worth $500-600? Good for someone that needs an new engine and a spare trans?
rer233
My tercel:: Multiple
Post by rer233 »
looks like milwalkee cars rust even worse than baltimore cars!!
A skilled welder could fix all that. The way it is now, it does not look safe to drive. You have the '87 grill and steering wheel, but also the '83-85 inclinometer, did you retro fit that into it?
In Australia the inclometer was not standard in the later model but I think it was an option? Seeing as that car has the sunroof/AC and nice interior. it might be worth rebuiding the underbody if you had the skills?
rer233
Post by rer233 »
problem is- if that area is SO rotten, how bad is the rest of the unibody? i've had some rusty t4wd's, but never anything like that! parts car far as i'm concerned. ANYTHING can be fixed, but does it make sense?
rer233
Post by rer233 »
now THAT'S rotten- how are yhe control arm mounts?
nothing a coat of paint won't fix!
deejay1272
My tercel:: 1985 Navy Blue Tercel Wagon SR5 4x4 now with Weber 32/36!
Post by deejay1272 »
Anyone wondering how this one has the inclinometer -- it's an '87! I thought those were discontinued after '84.
i put an inclinometer in my '87, i figured olga19 did the same.
incidently, in the manuals it is referred to as a clinometer. engrish maybe?
Lets see, to incline means a slope or grade, so an Inclinometer means to measure the slope. So inclinometer is the correct modern use if measuring the slope is our intent. But interestingly the on-line dictionary states the compound word dating from Indo-European means; in- into or toward, plus cline, to lean. So clinometer would be more accurate, because you are measuring how far the car is leaning, rather than the angle of the slope.
I like using mine as an accelerometer, to see how fast it can go around a turn. I should calibrate the scale into percent of one g.
holy f*ck, that accelerometer bit cracked me up. true nerd humour, i love it.
thank you for your sleuthing, petros: henceforth, i shall refer to these things as clinometers! so let it be written, so let it be done.
