Hello,
I need to replace my fuel level sender but am not sure where to find NOS parts for the 4wd tercel. Any ideas?
Fuel Level Sender
- My tercel:: '86 SR5 6 speed
Re: Fuel Level Sender
I don't know of any company who sells a sender aside from maybe the dealer. If your current sender still has some continuity then you can probably get away with just cleaning the contacts and bending the rod that holds the float. I think there is a write up on this forum, but it's fairly self-explanatory.
yeah it was actually rusted so bad from terrible fuel that the arm was seized. i loosened it up, had no readings, but put it back in anyway. it seems to be working properly. who knows?? thanks!
