Heater switch question
- My tercel:: 1985 SR5
I have noticed that the 4 speed switch in my car only works in the two highest speeds. I have not attempted to get at the switch...yet....I have a bad back and I would like to avoid 'under dash acrobatics' if possible. Could this be a matter of contact cleaning or are these things prone to old age failure? Suggestions?
Re: Heater switch question
Ok, I may have found what I needed to know via the search feature....should have gone there first, duh.
- My tercel:: None
Check the blower motor resistor, its behind the control panel, not too difficult to get to.
2015 Honda Fit EX "Malachi"
Thanks. I think that is what I read about when I used the search feature. The resisters that are behind the glove box? I read the 'fix' someone used for splicing the broken wires back together. I will tackle that in the near future, I don't feel like working on the old girl today....this old girl needs a break.tercel4wdrules wrote:Check the blower motor resistor, its behind the control panel, not too difficult to get to.
That's one of the big dangers when working under the dash...hard to get to stuff and hard on the back. I think the best bet is a pair of knee pads instead of sitting.
second to last post here, i replaced the resistor pack recently and posted some pics. i imagine the resistor packs from all the hatchback and coupe tercels should probably fit too, though i haven't checked.
https://tercel4wd.com/forums/viewtopic.php? ... 1&start=15
for years I was so stupeed , most of the work is at the front of the controller to replace the switch except once to do kneeing to disconnect the wire shocket. have fun
That looks pretty easy. I will be haunting pick and pulls soon to find a replacement. Thank you.
