Needed: '85 Caliper Mounting Bracket, LH Hatchback
jeff.built
My tercel:: '85 2WD 5 Door
Post by jeff.built »
Looking for just the torque plate for an '85 5door, drivers side. Finally did the half-shaft repair but twisted off a bolt on the mounting plate when removing the rotor. Junk yards in my area are not too helpful so thought I'd try on here. The old torque plate is at the mechanics who says he can remove the bolt without damageing the threads. As it is cracked already on the front rib, a spare would be handy.
I am in MD if anyone can help me out. Only rush issue is that the half-shaft broke down 2 days prior to an emmissions test. Have to get it driveable simply to take to the VEIP. Otherwise I'd wait till later.
Thanks.
Re: Needed: '85 Caliper Mounting Bracket, LH Hatchback
I am pretty certain the 4wd wagon uses the same front brakes (they appear the same) as the 2wd cars. I have one from a Tercel4wd you can have, but you need to verify it is the same part. It will take a week or more to get to you this time of year unless you want to pay for priority mail. PM me if you want it.
