Tilt steering colum
Tilt steering colum
What year steering colum will fit in a 1983 4x4 wagon? Does anyone have one,I'm in Butte Montana. Thanks.
Re: Tilt steering colum
You could try http://www.car-part.com/ and put in that year to see which other years will work...maybe the 2WD and hatchback will work?larry mcgrath wrote:What year steering colum will fit in a 1983 4x4 wagon? Does anyone have one,I'm in Butte Montana. Thanks.
Or go to the EPC in this Forum and see what the part numbers are.
It might be possible to swap out the whole tilt steering column, and plastic trim, from an '85 or newer. I considered it for my '84, but changed my mind. I like where the non-tilt column puts the steering wheel, and it would just add weight and complication I would not even use.
