Looking for Ignition Vacuum Advance
jebudallaha
My tercel:: 1983 SR5 4X4
Post by jebudallaha »
Hey,
Anyone have an old functioning vacuum advance kicking around I could sure use it. I'm looking for the dual one that you find on the M/T (the car it's going on is an '83) with the two ports and not the three that you see on the A/T. If you have one let me know the price. Thanks.
-Aaron
Re: Looking for Ignition Vacuum Advance
2 things you MIGHT be able to do: run with no vac advance...I still get good mpg...idle might suffer a little....timing is advanced some. Remove the "can" and grind around the outside crimp...take it apart and repair the diaphragm.
When I looked to replace them....think you needed to buy a whole new or rebuilt dist.
garyfish
Post by garyfish »
takza wrote:When I looked to replace them....think you needed to buy a whole new or rebuilt dist.
I helped a friend of mine replace the vac advance on his dizzy a few months ago. He bought an aftermarket vac advance from Napa for about $62 and the only kind available had 3 vac ports.
I did mine about a year ago and got the part from Rock Auto for about $56 + shipping... but I was buying a whole bunch of other stuff from them so the shipping was no big deal. Again, mine had the 3 vac ports.
You can just plug the extra vac port you don't need, I think.
Hope this helps.
garyfish wrote:
takza wrote:quote]
Hope this helps.
the top inside port with the very small hole (pin size) can be plugged
its for the high altitude stuff
If you close off a port on an extra diaphram...you might keep the advance from working right?
My third port (the one with the constriction) is plugged, as STL is not very high up in the mountains, so no need for the HAC valve...
No probs.
I usually check the vac advances on all the dist I find on every 3a or 4a equipped engine at the local pull-a-part. Most of them are shot, it is rare to find a good one. And it usually does not last very much longer anyway.
I am considering grinding off the swagged lip and see if I can not make a new diaframe, and find a way to make the vac advance serviceable with a removable clamp around the pie tin. It would save a lot of money in the long run, and solve the problem for all future vac advance issues.
