This ad appeared on Craigslist nearly 2 weeks ago so I don't know if these wagons are still available... I live less than 2 hours away but haven't called the guy to find out, because I don't have the capability to move or store these vehicles.
Here's the relevant portion of the ad:
lots of free stuff-all scrap metal or use as parts-as is where is-im not sure what works and doesn't work anymore.
... 2 toyota tercels both 4wd 4 doors- 1983-1988 models
-one with over 200k miles-was parts car-ran when parked 8 years ago-low compression in one cylinder and no 5th but did drive from eureka with no issues.broken front window and some damage to hood and lh fender from falling a tree too close.
other is under 150k, salvaged title( bought from sleazy car dealer in eureka), needs cv replaced every year or two due to accident but cant tell.some rust- ran great till engine blew timing chain or dropped a valve 11 years ago- both have 3ac engines, 5spd-ac, have title- ...
... all free must remove asap-bring trailers and 4x4's- will load appliances- you remove cars-
call or text 541-671-0584
no tire kickers- get'r done
will post pix asap
