What is it with old Toyota horns?
mikey
My tercel:: 85 4WD
Post by mikey »
What is the secret to keep my horn working reliably? I've got this problem with my '86 Tercel, I had it with my '84 Tercel, and come to think of it, I had it with my old '85 Camry. I take the horn part of the steering wheel apart, clean everything, put it together, and all works well. Then, days or weeks later, when I have to actually use the horn, it won't work! Or maybe it will.
I'm almost certain that the problem is right at the horn button, but it seems like voodoo. Help?
Re: What is it with old Toyota horns?
it is just oxidation build-up on the contact surfaces. Try some tuner cleaner spray, or a electrical contact lube like LPS or Corrosion-X spray, CRC, etc. (not WD-40), it should slow corrosion formation and improve the electrical contacts. This is not unique to Toyota horns, all my old cars have had this issue, Volvo, VW, Porsche, Nissan, etc.
Electrical contacts make tiny arcs when contact is made, and this allow corrosion to start, and than reliable contact is eventually lost. The sprays that prevent corrosion from forming also allows electricity to pass through the compound.
garyfish
Post by garyfish »
here's links to a couple threads that may prove helpful:
https://tercel4wd.com/forums/viewtopic.php?f=4&t=4008
https://tercel4wd.com/forums/viewtopic.php?f=2&t=2040
let us know how things work out for ya
Might go the Eye-talian air horn route? I doubt that it's the switch...more likely the horn is rusted/corroded? They are like a buzzer...contacts eventually wear out?
I've had a set of FIAM (?) that I've used for +20 years on various cars. Last set I bought were tuned "American style"...my wagon sounds like a '73 Caddy. :mrgreen:
I couldn't even FIND the OEM horn on my wagon...took a while.
Trev
My tercel:: 83 Tercel wagon:)
Post by Trev »
I refuse to use my horn. I think all Toyota horns sound wimpy. Most people will probably think a moped was using its horn.
1999 Dodge Cummins 3500
1983 Toyota Tercel 4wd Wagon
GF's - 1986 Toyota Tercel 2wd Wagon
If after resolving the horn button problem (keith has a great post in the link garyfish provided) you want to add horns - https://tercel4wd.com/forums/viewtopic.php? ... orn#p29677 .
blade
My tercel:: No tercel. (stolen)
Post by blade »
well i did a great switch i took the horn's (yes two) off a 1999 ford f150 and redid so me wires and BAM my horn is soo dam loud i used it when a cop cut me off and i scared the shit right out of him i saw him jump :twisted: lollollollollollollol
