another issue..
skulley
My tercel:: 1987 wagon 4wd dlx
another issue..
Post by skulley »
So my Terk tends to sound kind of loud when idling. The fan for the motor comes on and there is a ticking noise. Is this normal? Is it the thermostat maybe? It doesn't seem to be overheating but should it sound like this? :?:
Re: another issue..
I do not hear a ticking sound when my fan comes on. How fast is the tick? Is something hitting the fan perhaps, or a bad spot on the fan bearing?
skulley
Re: another issue..
Post by skulley »
Ok so maybe it's not a tick..I don't really know how to describe the sound. The fan does come on though, is this normal?
Re: another issue..
my fan comes on when it has been idling and not moving after about 1 min, that is normal. I do not hear any noise other than the fan motor running in a hum sound.
Re: another issue..
Might be the Air Suction system if you have the California model...the reed sticks and allows exhaust to escape.
If all else is in order...the fan switch might be bad...it defaults to always running when it goes bad.
Could be the thermostat....
