chilibilly wrote: Does the brake light usually come on in this situation? I realize the Alternator and regulator should be replaced at the same time, but I would like to isolate the cause for future reference.
I researched this on that Google group and it seems that having both lights on is typical of a lot of Toyota cars in the '80s...'90s or thereabouts......quite a few examples.....
***Rick Jones***
***Toyota Master Diagnostic Technician/ASE Master/L-1***
had the same problem, traced it down to the plug in connection at the
alternator.
One of your diodes in the altenator is bad. The alt will still put out
fine but it causes these two lights to come on. You have to buy the
whole alt. You cannot buy just diodes anymore.
I've got the "classic" brake light + charge light problem; car in question
is an 1987 Tercel (wagon).
A few months ago they started to flicker on and off -- time passed, they
stayed on for more time than off, eventually I wound up with the battery
dead in the middle of an intersection having to push it clear. No fun at
all.
Replacing the positive battery connector (which was pretty rusted) made the
problem go away for a month or so, then it came back. Replaced negative
terminal, ground connector from -ve battery to body, no improvement.
Checking things with a voltmeter, yup, the alternator was dead, no real
surprise so far.
Here's the annoying thing -- I replaced the alternator, and now while the
battery always charges and voltages are happy, the lights are constantly on.
This confuses me -- why would replacing the alternator make the actual
problem go away, but the warning lights stay there?
Things I've checked while trying to track this down that have been
recommended in this group in the past
Voltage across battery with engine off: 12.2v
Voltage across battery with engine idling: 14.5v
All fuses (in engine compartment and driver side door compartment) are
intact.
Alternator drive belt is tight.
Brake fluid is full. The light doesn't go off if I move the float up and
down, or if I disconnect the sensor, or if I disconnect the sensor and short
the other end of that connector with a bit of wire.
Voltages at the 3-pin connector on the back of the alternator:
12.2v on the white wire
11.9v on the black/red wire
1.6v on the yellow wire
12.2v on the 10mm wire screwed to the top of the alternator.
Connections that are good (with continuity tester):
-ve battery -> ground on body of car
-ve battery -> connector at bottom of engine
-ve battery -> engine case itself
-ve battery -> alternator mount bracket
engine case -> ground on body of car
Is there anything else I should be looking at? Is there something that's
likely to be wrong that I'm missing? Could I have knocked something loose
while replacing the alternator?
>>>> '87 has the internal regulator and the alt has a different plug........
** Let me know and I could email you all the collected WISDOM that I found.....text info.......
