Tecel 4wd sr5 at the local junkyard (Minnesota)
vtecn8ive
Post by vtecn8ive »
delete
splatterdog
Re: Tecel 4wd sr5 at the local junkyard (Minnesota)
Post by splatterdog »
How's the rust?
Which yard?
Thanks
vtecn8ive
Post by vtecn8ive »
UpullRparts East Bethel. I can't recall the extent of the rust. Not bad from what I can remember.
I really liked the white rims with center caps. Its identical to the 88-91 Civic rt4wd that have the same setup :)
splatterdog
I wonder if it's the same one they've had for a while. Is the steering column, driver seat and window regulator gone?
I may have an extra set of white steelies, if you are interested.
vtecn8ive
Post by vtecn8ive »
I don't need any. As I stated in the first post, I was just offering some help on getting parts for people if they needed them. I haven't owned a Tercel since my first car (8 years ago). I was just stating that I like the wheels/center cap setup and found it interesting that the Civic 4wd came with that setup... AFTER :lol:
You are in LUCK. The ignition actually has the key in it, all locks appear to be there too. Its dark blue in color. blue interior too. Everything is there.
the only thing missing were some fuses (fuse hunters). And the OEM floor mats that I grabbed (and plan to put on ebay within the month).
I was debating trying to grab the lock setup and ignition since I'm pretty sure its all matching. I have never seen keys in the ignition there, so jump on it if you can. I can't get out there till tomorrow, so if you needed someone else to grab anything let me know (with a compensation for time :) )
vtecn8ive
Post by vtecn8ive »
