'87 2WD Dash Instruments?
Rumrumm
My tercel:: '87 Tercel 2WD wagon, mostly original, owned since new.
Post by Rumrumm »
I have a plain-Jane '87 2WD wagon, & the cluster only has the speedometer, fuel gauge, & temp indicator to monitor things. Is there an optional Toyota cluster I could swap in to gain the tach, charging system gauge, oil pressure gauge, etc? Or should I simply buy aftermarket gauges, and what would be the best location to mount them? Maybe a universal gauge pod on top of the dash?
Thanks for any input...
danzo
My tercel:: '86 SR5 6 speed
Re: '87 2WD Dash Instruments?
Post by danzo »
SR5 Tercel wagons added the tachometer which should plug into your wiring harness. I have one with a non-working fuel gauge if you want it, just install your fuel gauge and it will work. The other guages you mentioned will have to be aftermarket.
