Was checking out the three dead trannys I have.
Two are 3.727 to 1 (41 teeth on ring, 11 on pinion)
But one was an oddball 3.153 to 1 (41 teeth on ring, 13 on pinion) (had a larger diameter flywheel too)
It was connected to a 3ac engine out of a Tercel 4wd Wagon.
Ten years ago a guy gave me the engine and tranny after he replaced both in his car (the tranny was broke and engine was high milage)
I re-ringed the engine and its still kicking in one of my cars.
I wonder if he replaced the rear differential?
Where does that tranny fit in to all this Tercel 4wd Wagon stuff?????
Have Odd differential with 3.153 to 1 ratio
- My tercel:: '86 SR5 6 speed
Re: Have Odd differential with 3.153 to 1 ratio
Are you sure the pinion gear has 13 teeth? A 3.15 final drive is unusally low. 12 teeth would make that a 3.42 which I believe was used in Tercel hatchbacks and maybe fwd Tercel wagons (sorry I don't have my Chilton books handy). Is that gearbox 4wd or just fwd? Do you want to know what car it fits so you can sell that gearbox?
I just counted it again and it's definatly 13 teeth but I double checked where it came from and it was from a sedan.danzo wrote:Are you sure the pinion gear has 13 teeth? A 3.15 final drive is unusally low. 12 teeth would make that a 3.42 which I believe was used in Tercel hatchbacks and maybe fwd Tercel wagons (sorry I don't have my Chilton books handy). Is that gearbox 4wd or just fwd? Do you want to know what car it fits so you can sell that gearbox?
It was piled on top of the other bell housing that came out of a 4wd ( I did not notice that there was one underneath)
My mistake.
