e-brake hot to the touch, what's wrong?
- My tercel:: 1984 2wd 5 door
Hello all,
I have a quirky 1984 2wd 5 door. After running around town for a bit I have noticed the floor between the front seats gets unusually hot. The e-brake handle is almost too hot to touch. The heat seems to only be located on the floor in that area up to the stick shift. What should I check or get looked at? Is this something awful?
- Neu
Re: e-brake hot to the touch, what's wrong?
that is really weird, sounds like a driveline rubbing issue, maybe exhaust?
- Mattel
exhaust system - is that where the catalityc converter is located? (we never had them in aus)
Welcome to the Club!
Since you have a 2WD (5-door sedan ?), the drive train is moot.
As Mattel mentions, it must be the exhaust system and probably the cat - it is located in that area. After the next drive, take a look. But DO NOT park over grass or other vegetation - or in an area where there may be fuel fumes. Overheated cats CAN cause fires - or melt the undercoating, also causing a fire.
P.S. Most of our little cars are quirky; you are not alone.
I would agree other saying CATALITYC because they all have heating sheild and most of the toyota get rusted and fall apart , have to make heating sheild to install it , second inside the CATALITYC made of look like honey comb ,it get plug up over the years and cause flow resistance , exhaust flums have hard time passing through.
I think I disagree on the cat. On the 4wd, its further forward and I think its about in the same place on the 2wd. It could well be an exhaust leak right about this point though, that would make this area right toasty.
It sounds like an exhaust leak, or a faulty heat shield. But just to make sure, you might top up your trans fluid while you are at it.
- Mattel
where is the fuel line on those 2wds?
the fuel line is at the opposite side of 4WD ( 2WD fuel line on driver side , 4WD is at passager side ) the cat are slight forward from emergency brake handle , best wait motor is cold , jack the car up , start the car and put you hand on every exhaust connection and if you feel draft blowing
Yes - and partially yes.toughtercel wrote:the fuel line is at the opposite side of 4WD ( 2WD fuel line on driver side , 4WD is at passager side )
FU-33 *
* FUel system, pg.33 of the FSM.
Thank you all for the input, diagnoses, and warm welcome. It makes sense that its exhaust related especially with the location.
Thank's toughtercel I will give this a try.toughtercel wrote:best wait motor is cold , jack the car up , start the car and put you hand on every exhaust connection and if you feel draft blowing
I'd say take advantage of the situation put a billy in that location, you can brew up and drive at the same time, like in a British tank.
Just kidding, but it's not a bad idea to work out.
Like mentioned above...it could be low oil...had a similar thing with a 4x4 truck...transfer case was low and things got hot.
