each engine can i make in my TERCEL 4WD from other car model
ismailsrt4400
My tercel:: TERCEL 4WD 1990
Post by ismailsrt4400 »
hello
my tercel 4WD engine was in a bad situation and i look for replacing this engine with other from any other car model
plz tell me the other car model that can i take from it the engine and make it in my TERCEL 4WD
i have TERCEL 4WD model 1990
waiting for ur reply as soon as possible
sorry for my bad english
Re: each engine can i make in my TERCEL 4WD from other car model
are you sure you have a tercel? it was made between 1982 and 1988. You may have a corolla AWD wagon which was named the like the tercel as the carib sprinter ins some countries. In Australia lots of dealers get confused and call the cars the wrong name because the only Tercel we had is the 4wd wagon.
The best way to check is to pop the hood. Is the engine going across the body between the wheels as then it is a corolla wagon. Or if it is going in line with the body it is a Tercel4wd.
They look a little similar but are completely different mechanically.
Tercel easily accepts the 4ac and 3ac engines.
Corolla AWD accepts 4AFE to 4AGE engines.
I have never heard of a Tercel 4wd year 1990, I thought they were discontinued after 1987. Double check your model year. In 1988 they introduced the Corolla based All-Trac to replace it (totally different engine and drive train). Unless you have something we have never seen. Can you post or find a link to a picture of the car you have so we can see what you are talking about? The engines would be different for different models of cars.
Where do you live?
toughtercel
Post by toughtercel »
last one 1988 ; i have auto tercel 4WD sitting on my driveway tag says >DEC 1987 #306,687 < which mean 1988 , i put that information in "production number " few days ago .
ismailsrt4400
sorry for the late reply
this is the photo for my toyota
i found in the chassis
engine=3A
is that the type of the engine?
Neu
My tercel:: 1985 SR5 No Mods
Post by Neu »
I'll say with 100% certainty that that IS NOT a 1990 model. We can't see the headlights in that photo, so I'll just say it's probably a 1985 to 1986 model. SR5 model. 3A engine.
Highlander
Post by Highlander »
Looks just like my '85 SR5 right down to the wheels, only mine's Gold. 3A (or3-AC) is the correct motor, SOME of the 4As fit in easily-it depends on where the dizzy is, I believe.
'83 SR5-299K, -tRusty!
'85 SR5-265K--GOLD
toughtercel
according to the picture , it's 83 to 86 , how can you tell if not "83" but look like "85-86" , front side marker are orange "83-86" , front side marker are clear with little orange are "87-88" ... but the toyota's mag wheels are "83 ,84 and up ??.
just look up the I.D. tag on driver door jam , there the month/year will tell you AND on valve cover will tell you "3A, 3A-C , or 4A or maybe something else
Than that means any 3A, 3AC, or 4AC engine will work. These came in the '83-87 Tercels (2wd or 4wd) and Corollas (any others car models?). There are other engines that can be made to fit, but they take a lot of messing with to do a conversion. The 3A or 4A engines should be a direct bolt-in swap.
ismailsrt4400
thank you for all
CathodeRayTube
My tercel:: 1985 4x4 Automatic - restored
Post by CathodeRayTube »
that picture is on some forum elsewhere on the net...iv seen it many times before...and ripped off all the other pictures from the same site...
85 T4 DX 4x4 Automatic
83 T4 SR5 - junker/parts
94 4Runner V6
86 Mercury Grand Marquis
88 Lincoln Town Car
90 Yugo GV+
yep, that's the jalopnik "Down on the street" Tercel
http://jalopnik.com/340958/1985-toyota- ... ewcomments
read the comments and feel the love.
Neu
Post by Neu »
The fact you guys knew that makes me love this forum.
Jonesy
My tercel:: '84 Toyota Tercel SR5
Post by Jonesy »
Neu wrote:The fact you guys knew that makes me love this forum.
Haha yep, I'm impressed. :)
