6 speed TRANSMISSION
toughtercel
Post by toughtercel »
i was checking out some stuff in craigslist and one of them mention two different tranny by different year 1984 Tercel 6 speed transmion for 4x4 wagon - $200 (bellevue)
Is that true or he does'nt know any better
Reply to: sale-y7nwn-1074568651@craigslist.org [Errors when replying to ads?]
Date: 2009-03-14, 10:05AM PDT
TERCEL SIX SPEED TRANSMISSION, WORKING WHEN PULLED OUT OF 1985 TERCEL WAGON, THIS TRANSMISSOIN WILL NOT FIT ANYTHING ABOVE 1985 TERCEL WAGON.
$200.00 OR TRADE FOR 1986 TERCEL TRANSMISSION.
PICTURE IF INTERESTED
terkill
My tercel:: 1987 Toyota Tercel 4WD
Re: 6 speed TRANSMISSION
Post by terkill »
he is probably misinformed or confused. I'm almost positive they had the same transmission from 1983-1986 then in 1987 they changed it up. the transmission is the same in a 1986 then in a 1985.
"If parts ain't flyin, you ain't tryin"
Neu
My tercel:: 1985 SR5 No Mods
Post by Neu »
The guy in the ad was probably thinking about the gear ratio difference..
toughtercel
just want my head to be straight up , 1983 thru 1986 do they all have the same transmission's mount postion to the different year body (83 -86) WHAT ABOUT 1987 AND 1988 , can i mount 1983 4WD tranny to 1987 4WD body , i know the ratio are differnt , just talking about tranny mount to varie year body , thanks
SynthDesign
Post by SynthDesign »
No. I spoke to Gunnar about it. He did in fact have a different type trans. I believe it was 2wd. not 4wd. Where as he had an 86 and was in need of 4.10 4wd 6spd trans.
I think he sold both his all-trac and t4wd.
2005 Toyota Sienna, work van
85 Toyota MR2 (Blu)
83 Mazda RX-7 Mariah Widebody
J Dumarais
My tercel:: Toyota Tercel 4WD Wagon '86 & Jose 87' Tercel 4WD Wagon
Post by J Dumarais »
Im not sure if i anderstand the conclusion but i have a 87' tranny 6 speed that i want to transfer into my 86' tercel wagon 4wd? His it's gonna fit, work, Broke?
Gottolovem
Post by Gottolovem »
83 and 84 =3.73 ratio
85 86 87 88 =4.11 ratio
This is a very old thread :oldgeek:
i think its 83-85 with 3.73 gear ratio differential 11 teeth on pinion 41 teeth on ring gear
86-88 with 4.1 gear ratio differential 10 teeth on pinion 41 teeth on ring gear
if i remember correctly the mfr cut off date was nov 1984 for 3.73 and a 1984 mfr date would be a 1985 model
either way the tranny itself is interchangable between 83-88 model years
just seperate the tranny from the differential housing so you can keep your old differential housing
and there is no worry about gear ratios
Gottolovem
:) Xirdneh i'm sure your right
I own two 85's both with 4.11 raitos.
Makes it all the more important to look at production dates if someones car is titled as an 85
Mine must be late 85 making them the next years models
jimcrazy
Post by jimcrazy »
mine is titled as a 85, and the door tag says april 85
Ridlbox
Post by Ridlbox »
Gottolovem and I have replaced a couple of trannies throughout the years like you says the trainees themselves are interchangeable if you just separate the diff from the tranny
That's my new goal 8)
