Ciggy lighter not working
Got to drive 500miles to Adelaide from Melbourne (Aus) on Thurs and wan't to power my ipod through the cigerette lighter..
I have the ipod adaptor but the cigerette lighter doesn't worked.. replaced/checked kick panel fuses (footwell) and under bonnet. all seem OK..
is there another fuse that I may have missed or ..
can I just rig up with some gaffa tape a power lead (say off the radio) and earth to the ipod adaptor (not sure if the amperage and all that stuff is correct).
cheers in advance!
Matt
icE
Post by icE »
hmm i hook up a power invertor to my cig lighter, so i can plug anything into the car (that doesnt take up more than 150 watts anyway). I'm planning on getting one of those extensions so you can plug in 4 or 5 cig-adapter items, so i can add 4 lights and my blacklight on the dash uses the power invertor (got it from walmart for 15 bux, was made to be put in the house lol).
To answer your question, i believe there might be a way to get another cigarette adapter from another car (all the same size anyway) and hook it up directly to the battery, just like an amplifier would. Or, there are power invertors (like the one i have) that don't plug into the cig lighter but directly to the battery, so if your iPod has an AC adapter to plug into the house, you can use the power invertor to power it up. I used to do this in the tercel, i had computer speakers with a sub in the back seats, and a portable cd player, all hooked up to a power strip which is connected to the power invertor, and it powered everything pretty well :) Shouldn't be too expensive either, as an iPod doesn't require that much voltage to power on B)
Hi IcE
Is there a more temporary way around this as I'm not going to get time to take this into the electric workshop or get parts
can I attach the end of the adaptor to the earth and the prongs that stick out the sides to a power lead?
I will aim for a more permanant solution on return from South Australia
cheers
Mattel wrote: can I attach the end of the adaptor to the earth and the prongs that stick out the sides to a power lead?
Probably need to be sure your POLARITY is correct...(+) & ( -) ........
GTSSportCoupe
Post by GTSSportCoupe »
Mattel wrote: Hi IcE
cheers
Hi Mattel,
I would recommend checking both the fuses (as you have) as well as the wire that attaches behind the cigarette lighter. I've seen these wires slip off before, especially if someone has had your temperature control bezel apart before. You could take apart the bezel and asociated parts enough that you can make sure the wire connector is attached behind the cigarette lighter.
Your radio power should provide enough power for your computer (if not, it'll just blow the fuse). I'm fairly certain that the tip of the cigarette lighter connector is +12V, and the ring (sides) are Gnd. As Takza said, make sure you check this.
Current:
91 LJ78 Landcruiser EX5
95 A32 Maxima SE
Former:
87 AW11 MR2 Smallport 4AGZE
93 Taurus SHO ATX
86 AL25 SR5 6spd 4wd
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
