I was wondering where the negative spot on the ignition coil is? It says to connect there but I am lost with toyotas.
If anyone has a picture or a diagram or directions to where it is it would help a lot.
tachometer..
- My tercel:: 1987 Toyota Tercel 4WD
tachometer..
"If parts ain't flyin, you ain't tryin"
- My tercel:: '86 SR5 6 speed
Re: tachometer..
Page 217 of the Factory Service manual (FSM) has a diagram which should help you. It is posted on this site in the Repair Guides section. Are you trying to install an aftermarket tach? If so then I would guess the negative coil terminal would suffice for that.
If you want a factory gauge cluster I can send you one cheap, it should plug into your wiring harness. But you would need to supply your own working fuel gauge.
Re: tachometer..
Nah its a separate aftermarket tach, mounted on the Apillar.. thanks though!
Re: tachometer..
there are only 2 wires going into the distribuitor one of those is the signal you are looking for, if i remember correctly is a orange one
