Charcoal canister - need clarity
scouttster
My tercel:: 1984 Tercel Hatchback
Post by scouttster »
Did my due diligence and checked the FSM. Still confused.
Also read through the posts, nothing..
The inlet or outlet at the bottom my charcoal canister - should that be open to atmosphere?
Thankyou
Terkey Hatchback
Re: Charcoal canister - need clarity
Yes.
Air enters through the canister's tube which is stuck inside the "chassis" rail/compartment.
Fuel vapors end up in the canister from the tank and air is pulled in thru the bottom under certain conditions to feed these fumes to the engine. You don't want to get oil or anything in/on the carbon inside it....but clean the filter.
