wiper linkage
Don D
My tercel:: 1984 tercel wagon
wiper linkage
Post by Don D »
Hi there Im new to these forums but have been hear a few times before . I have searched the repair forum and did not find any thing about my problem my wiper linkage has broken at the motor arm, I cant see what holds it together. can anyone direct me to a photo or parts diagram so I can see what I'm missing . thanks Don
Oh the car is a 1984 tercel wagon 4wd. thanks again.
Re: wiper linkage
Welcome to the Club!
Incidentally, props for performing Searches before asking the question!
I don't think this has been mentioned before. I looked in the FSM and could find nothing on the linkage. However, the AutoZone site does have some mention and pix here which may cover it: http://www.autozone.com/shopping/repair ... 5280052167
If you would - when you resolve it - take some pix/write a Guide to your solution.
Where are you located?
Jarf
My tercel:: Currently without
Re: wiper linkage
Post by Jarf »
There are no pics to be found in any manual.
IIRC there should be short crank arm on the motor. wiper transmission snaps onto that arm and connects the 2 pivots to the motor.
Arm on the motor will likely part of the motor assembly. If you problem is on the arm to the pivots, that arm should come with the wiper transmission (wiper pivot assembly). Either way I would suspect that you have a seized wiper pivot that has caused your failure, with everything disconnected you should be able to move all bits by hand pressure. As they work they will tighten up with friction.
Good luck
As for what holds it together, usually snap fit plastic connecters. If they are apart it has seen too much stress and popped apart, you can reassemble till the cows come home and it will just keep coming off (btdt) replacement is the only cure.
