Egr valve
- My tercel:: 1985 Toyota Tercel 4wd auto no mods
Egr valve
Hey all, was wondering if anyone has an inside line on an egr valve. I've got an 85 tercel 4x4 automatic and every time I plug the small vacuum hose onto the top of the valve, the car runs rough once warmed up. At a stop light, after almost a minute, it seems to smooth out. I've tried to clean it out but to no avail. It had a bunch of carbon buildup and I got it all out, I just think it's had it. I've searched for one all over the internet and have seen them for $140-$170. Kind of steep for a 23 year old car, so if anyone knows of a website that has them cheap, or if there's any place that may remanufacture them, if possible, I sure would appreciate the help.
Re: Egr valve
There's a writeup in the Repair section. Problem sounds like it's the vac modulator that controls the EGR valve. Might fix it by spraying a bit of WD40 into the ports and checking the vac lines to it and the EGR. A temp fix is to undo the vac line to the EGR and plug it till you get it figured out.
