Will these fit the tercel?
scotisha
Post by scotisha »
Hey all,
I have been trying all the wreckers in Western Canada for 14" rims for my tercel (I want some tire options :D) but have found nothing for under $125 each. I found these and was wondering if they will be a good fit?
http://reddeer.kijiji.ca/c-cars-vehicle ... dZ49348288
I read somewhere that the tercels are 4x100 and have a 54.1mm hub ring and that the 91-95 escorts are a direct fit. These look like 4x100 and I am wondering how I can measure the 54.1mm? I guess that I could get some spacers but I would like it to be a direct fit. And are the rims supposed to be 5" or 5.5"
Thanks,
S
Driver: '86 4wd Tercel Wagon
Fun: '98 BMW M3 sedan
Now I have the best of both worlds!
Re: Will these fit the tercel?
viewtopic.php?f=7&t=52
The 14" steel escort wheels I'm using fit exactly on the toyota hubs...both lugs and hub part....mine are slightly wider and have more track than stock wheels.
Find a set of the 15" Escort GT alum wheels? They had low profiles on them.
scotisha
Post by scotisha »
So I found some 14" Escort Alloys on Kijiji for $50 with only $30 shipping! I am getting some GY Assurance Tripletreads for them. It was a toss up with the Nokian WRG2's but they didn't have them in stock and I need tires now...
ptothej
My tercel:: 1987 Toyota Tercel 4wd wagon, lifted aprox. 3" in the rear, 2" in the front, tube bumper, 2k atv winch, K&N air filter, custom red/black paint job, custom shift knob
Post by ptothej »
I was wondering about bigger tires for my tercel since I lifted it.. I was thinking 14's would be ideal.. bigger but not too big. But the diameter I was thinking of was going to be 2" bigger then what Im running now (175/80R13), in 14's to get the 2" was gonna have to be 195/80R14 Im wondering if jumping to a 15" rim would be more cost efficient and the size be more available? Not thread jacking just thought since we are all discussing wheels and whatnot
Im awesome
Neu
My tercel:: 1985 SR5 No Mods
Post by Neu »
jumping to 15'' would be better, there are more options available when it comes to aggressive traction.
ptothej
Post by ptothej »
Thank you, Ill keep an eye open for that!
Im awesome
scotisha
Post by scotisha »
Is there any difference in performance or ride with a bigger rim size?
Technically a bigger diameter wheel/tyre combo will make your gearing a little taller my 14" make my car use say 300rpm less at 100kmh which may be an issue if you go off road a bit. Also my Speedo is about 6% off. You can use http://www.miata.net/garage/tirecalc.html to find out speedometer difference.
My new tyres seem better all round, especially have a better ride around the cobblestones and potholes around where I live and seems a lot smoother on the highway quieter to - but this might also be due to my choice of tyre.
