3A crate motor: $300 (San Luis Obispo, CA)
alehander
My tercel:: She's an eighty-five, SR5, four wheel drive, AUTO-matic, HY-DRO-MATIC...
Post by alehander »
The title pretty much says it... a complete long block, valve cover to oil pan, professionally rebuilt. If you want more info, email or call 805-783-0660, Alex
Lenin zhil, Lenin zhiv, Lenin budet zhit'
SaltyDad
My tercel:: 1987 wagon sr5 4wd
Re: 3A crate motor: $300 (San Luis Obispo, CA)
Post by SaltyDad »
Alex,
Do you still have this available?
Scott
alehander
Post by alehander »
Nope, long gone. I do have a "backup motor" I've been slowly building: a used, low-mile 3A short block (with hone marks still showing) with a new head. Includes beadblasted intake & exhaust manis, good carb & dizzy w/all the emission bits. $300
I'm in LA now, not SLO. Cheers, -Alex 805.610.7752
toughtercel
Post by toughtercel »
what the differance between long block and short block , is there stamp on block or ??
Neu
My tercel:: 1985 SR5 No Mods
Post by Neu »
toughtercel wrote:what the differance between long block and short block , is there stamp on block or ??
short block is a really bare bones bottom end of the engine. so it can mean either just the block (cylinders with no rods, pistons) or it can have the pistons, but no head.
long block is everything, including the head. but none of the other stuff like carb, intake, or whatnot.
at least that's my understanding.
toughtercel
ohh i see thank you
CathodeRayTube
My tercel:: 1985 4x4 Automatic - restored
Post by CathodeRayTube »
i thought a long block had all the extra accessorys with it...manifolds, starter, alternator, pumps, belts etc...atleast i saw an engine on ebay advertized as a long block and it had all the extra shit with it..
85 T4 DX 4x4 Automatic
83 T4 SR5 - junker/parts
94 4Runner V6
86 Mercury Grand Marquis
88 Lincoln Town Car
90 Yugo GV+
Neu
Post by Neu »
a long block is everything but the bolt ons...
it's pretty much the top and bottom half of the engine. the block and the head.
buffalomesa
My tercel:: 1986 Dlx 2WD Wagon
Post by buffalomesa »
A short block is the block, pistons, and crankshaft, as an assembly. It may have the rear main seal, but usually will not have the oil pump. A long block also includes the complete head, timing components, and oil pump, plus all the completion gaskets. A block with no internals is a bare block, and a long block with the manifolds, water pump, valve cover, oil pan, etc. is an engine assembly.
Those are the definitions, although a lot of sellers don't know what they're talking about.
toughtercel
ok i get it now , "short block " means any equipments add "inside the block" and
"long block " means any equipment add "outside the block or add on the block"
so as for "starter" its add to tranny that where one hole has thread in the tranny , or "alternator" have to add bracket which attach to the block. hmmm interesting
alehander
Post by alehander »
Now that that's all cleared up, does anyone want to actually buy the engine?
