idle question
fuseone
My tercel:: 87 sr5 tercel bone stock lol
idle question
Post by fuseone »
hi i have a 87 tercel sr5 and wanted to know what the idle speed should be set at? what rpm should i have it at
Re: idle question
Welcome !
Did you do a Search here for the info?
It varies for MT and AT.
An excellent info source is the AutoZone site.
The link to the site is: http://www.autozone.com/shopping/repairGuide.htm
This is even better than the FSM (available on our site) - plus, it has photos, whereas the FSM has only diagrams.
This also has all of the vac diagrams.
Re: idle question
Usually on the sticker under the hood or shoot for something below 1K rpm?
Highlander
Re: idle question
Post by Highlander »
According to the FSM, Idle speed depends on Whether you have AC, PS, and or an auto trans. if you have none of those, it should be 650 +_150, add PS, it should go up by 100, etc.-- AS Archinstl said, check your underhood sticker.
'83 SR5-299K, -tRusty!
'85 SR5-265K--GOLD
