Stuck in gear. Manual.
Neu
My tercel:: 1985 SR5 No Mods
Post by Neu »
So i'm driving down the road and I put it into 4th, now I can only get it into 3rd gear but it feels like it's 4th. Even when the stick is in the neutral position it's in either 3rd or 4th gear.
Help? This is my ONLY running car. what could it be?
hberdan
My tercel:: Sold my 1987 Tercel Dlx 4x4 Wagon but miss driving it everyday. I don't miss working on it, though.
Post by hberdan »
Check your clutch cable.
Neu
Post by Neu »
i posted on another forum and they said check my shifter linkage.
Snax
Post by Snax »
Yup, sounds like a cable or linkage problem. The fore and aft assembly is probably fine, but the lateral one may be boned.
You may need help to confirm what's going on, but have one person look at the linkage on the transmission while the other person moves the stick laterally. If they both move in unison, then the gear selector box is the culprit. If they don't move in unison, then you've got a broken cable or linkage.
83 SR5, 32/36 Weber DGEV
94 Escort LX Wagon
11 Flex SEL
keith
Post by keith »
Snax wrote:Yup, sounds like a cable or linkage problem. The fore and aft assembly is probably fine, but the lateral one may be boned.
It's a top loader and the linkage is internal. Could be ice in the box at the top of the transmission where the stick enters
I'd run it till good and warm...take the boots out inside on top the trans...get any water/rust/grit out of the shifter area...pour in about 1/2 cup gear oil...and get some kind of boot over it.
You might get lucky and have no internal damage. Good idea to change out the gear oil.
Don't ever want to be forcing the gear shift.
Neu
Post by Neu »
it feels like it bent...so i'm guessing my forks are messed up.
Neu
Post by Neu »
so im' still driving the car with only 1, 2, 5th and reverse. I do a lot of in town driving, and I'm hoping to keep driving this car until i can catch up on some debt and then put a new tranny in it!
