spark plug dilemma
mightyterc
spark plug dilemma
Post by mightyterc »
Went up to the pines for a thrash the other night. (Which by the way was awesome fun!, swingin mad nuts in the terc haha). Noticed that my car has lost a HEAP of power, and was even periodically running on 3 cylinders. On closer inspection, i noticed oil leaking out of the number 4 spark plug hole, on even closer inspection, i noticed that i was not in on the same angle as the other ones. That night, after removing the plug, i noticed the hole has been all crossthreaded by the deadbeat who had the car before me. What to do??
:evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil:
gemini recovery vehicle
keith
Post by keith »
First step would be a thread chaser. It may or may not work. If it doesn't, then you'll have to use a helicoil. The trick will be keeping all the shavings out of the cylinder.
http://www.amazon.com/Lisle-Spark-Plug- ... B0002JMIYU
http://inpcars.com/spark-plug-thread-repair-kits/
http://www.mytoolstore.com/kd/kdengi11.html
Typrus
Post by Typrus »
The shavings probably wouldn't hurt the engie that bad. However, the cat might not like it one bit. Keep in mind, the head is aluminum and the cylinders are hardened iron.
BUT.... A vaccum with a narrow spout attachment might be used to suck the majority of them out.
If you do use a chaser, be careful to chase the original threads. If you aren't careful, you could end up chasing the bad ones and create an issue with sealing.
Post by Chris »
A little trick that I use for keeping thread shaving from where you don't want them is to put grease on the tap flutes when tapping. The shavings will embed into the grease as you tap. Remove the tap frequently, clean , regrease, and continue tapping.
jetswim
My tercel:: 1987 Tercel SR5 4WD Wagon
Post by jetswim »
And keep a magnet handy too!
A chaser and a tap are two different beasts? Less chance of messing up with a chaser?
Typrus
Post by Typrus »
A magnet will do you absolutely no good on an aluminum head.
