84 tercel dlx 5dr hatch with 3A + auto
1) Paradise Racing: Paradise Racing also has the Paradise Racing Power Pack for the Toyota 4AC and Toyota 2/3TC engines!!! It includes a Weber 32/36 Carb Kit, Schneider Cam & Dual Valve Springs. It will provide a Dyno Proven 40hp and an improved power band up to 8,000 rpms!!!
- Will this kit fit on my car?
- Weber 32/36 DGEV... right?
- Difficulty of install by mechanic
- How will this effect my engine... (powerband up to 8000rpm)
2) Auto to manual swap... 3spd auto swap to ______. What transmissions will work in my hatch... If i use a wagon trans will it work as a 5speed for me or 6. Or should i stick to the 4 speed in the hatch's. Which would work better. (top speed on speedo right now 140km if it matters)
3) What would i need to help the engine to work at its Best and get the most out of the car... (fuel filter, pump...)
- im planning on doing a full exhaust after the above is done.
Thanks everyone.... when i do all this i'll document it and post it up to return the favour for the advice...
