front ring and pinion
mailman
Post by mailman »
well went to do a tranny swap and checked things first. The ring and pinion are missing some teeth. Has anybody been here before. Where can i get the parts. The Mailman
Somebody had a catastrophic failure...guess that's what you'd call it...where one tooth at least...on the ring broke.
He had a writeup and some pics.
My front diff was run in metal powder for 2K miles or so...no issues that I can tell...yet.
shogun
Post by shogun »
iv had teeth gone missing but in the spider gears, ring and pinion fine, but if the ring and pinion broke, it wasnt set properly
mailman
Post by mailman »
Finally went after 129K. do you think toyota will make it right.
