How do you know it's time to do the valve clearances. While my car is idling I can hear a distinct ticking. Car runs perfect though.
On my VW engine as soon as the valve clearances are off you notice it right away in performance.
VALVE Clearances
- My tercel:: 1987 Tercel SR5 4WD Wagon
VALVE Clearances
Re: VALVE Clearances
It's pretty easy to remove the valve cover, and follow the factory repair manual using a feeler guage to measure the clearance. This is the surest way to check. No guess work here.jetswim wrote:How do you know it's time to do the valve clearances. While my car is idling I can hear a distinct ticking. Car runs perfect though.
Current:
91 LJ78 Landcruiser EX5
95 A32 Maxima SE
Former:
87 AW11 MR2 Smallport 4AGZE
93 Taurus SHO ATX
86 AL25 SR5 6spd 4wd
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
You can use some vac hose as a stehoscope to see if that ticking comes from the fuel pump.
But if they haven't been done...it's a good thing to do...IF you do them right.
I wouldn't wait for winter...things cool down too fast.
The big thing when doing them is the thing HAS to stay hot.
If you heard my engine clip.... My clearances were done not too long ago. It was cool out, and everything chilled too far down too quickly. Never bothered with it this summer. Likely should have.
