problem with accel....
T-Bone
Post by T-Bone »
When ever I give it gas my tercel hesitates like crazy. If I give it a little gas it doesnt seem to do it much. It takes forever for me to get up to speed. If there is no load on the engine and I rev it up with it in neutral or with the clutch in it revs up fine. But when there is a load then it has a big problems.
Daily Driver:
1988 Toyota Tercel SR5 4WD
3AC 2BBl Downdraft Carb
Project Car:
1993 Honda Del Sol Si
D16Z6 Head/Block
D16A1 Pistons (C/R 12.3:1)
Lollypop
Post by Lollypop »
T-Bone....
I have absolute no idea what nthe problem is for sure but I "say" its the carb ...My car is doin the ecact same thing ..its almost like the second barrel aint workin like it should...so I have a new Weber that should have been here 3 days ago and as soon as it gets here I'll install and HOPEFULLY it will fix my problem.
I'm curious to see the responses of the other guys.
=====Justin=====
1987 Tercel 2WD, 1983 Tercel 4WD
GTSSportCoupe
Post by GTSSportCoupe »
I'd say either your ignition timing is WAY off, or not advancing with rpm/throttle. OR, your carb is running too rich/lean, or maybe the choke is not disengaging.
Current:
91 LJ78 Landcruiser EX5
95 A32 Maxima SE
Former:
87 AW11 MR2 Smallport 4AGZE
93 Taurus SHO ATX
86 AL25 SR5 6spd 4wd
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
Try taking it out on back roads, loosen the dist hold down enough to turn it, rotate it some to see if you get some power without pinging. Might be your vac advance? Timing belt has jumped a tooth or cam timing is off?
