Carb and O2 Sensor...83
bobdavid
Post by bobdavid »
Forgive this newbee...but my 83 4WD Wagon seems to be running awful rich...black plugs, oil gets dirty quick, poor gas mileage. With over 350k on the original engine, I am guessing my O2 sensor is shot. Would a bad O2 sensor lead to a rich mix? Could this be as simple as replacing the O2 sensor?
Probably in the carb? Check the sight glass in front? New float and inlet valve needed?
Re: Carb and O2 Sensor...83
bobdavid wrote:Forgive this newbee...but my 83 4WD Wagon seems to be running awful rich...black plugs, oil gets dirty quick, poor gas mileage. With over 350k on the original engine, I am guessing my O2 sensor is shot. Would a bad O2 sensor lead to a rich mix? Could this be as simple as replacing the O2 sensor?
how much oil are you going through? maybee the engine needs re-ringing.
T-Bone
Post by T-Bone »
yeah, if the rings are bad you will get a lot of blowby and that will make the oil get dirty really fast.
Daily Driver:
1988 Toyota Tercel SR5 4WD
3AC 2BBl Downdraft Carb
Project Car:
1993 Honda Del Sol Si
D16Z6 Head/Block
D16A1 Pistons (C/R 12.3:1)
bobdavid
carb and O2 sensor...83
Post by bobdavid »
Ice -
The engine still does not use a full quart between 3k oil changes.
Typrus
Post by Typrus »
The O2 sensor isn't very important in our cars. It only controls an air-feed as far as I know.
It is cheap at about $25 and is easy to swap (providing your bolts aren't seized).
You may be looking more towards a re-ring and carb rebuild.
