Simply type the speaker size & brand, RMS/Peak power its running at, then post subwoofer size, location, brand, & RMS Peak power its running at.
ill go first
front: 2 Kicker ds40s running at 25RMS/50Peak
Rear: 2 Kicker ds693s running at 60RMS/120peak
Subwoofer: 12" Kicker CompVR running at 150RMS/300Peak
let's play the "whats your stereo system" game
1984 2wd wagon, "bottle rocket": http://www.myspace.com/1984tercel
1995 Isuzu TFR-S, "Shorty": no cardomain page yet
Pioneer DEH-P4600-MP 50x4 peak watt
2 Pioneer TS-1018 4-inchers
Description
- 40 Watts Max. Music Power (10 Watts Nominal).
- 1-5/8" Cone Midrange/Tweeter.
- Frequency Response: 50 to 20,000Hz.
- Sensitivity (Efficiency): 88dB (1W/1M).
- 4.9 oz. Strontium Magnet.
- 4 Ohm Rated.
2 Infinity Reference 512i
Took me finding a German site to get this lol
45 Watts RMS
Frequency Response- 80-20,000Hz
Sensitivity - 90dB
2 Kicker CompVR cd10 8-ohm 10's. 150 Watt RMS, 300 Watt Max EACH.
Sealed box setup, dual-chamber with barrier.
Rear cargo area, ~4 inches from hatch, facing hatch, offcenter to passenger side.
HiFonics Brutus Super-D-Class Mono-Block Amplifier. 1200 Watt rating, 1-ohm stable.
I essentially have ZERO bass without the subs, and often have them set just loud enough to fill the low end. It is capable of giving you a headache, and making young ladies rather uncomfortable.
I want 5.25's in the front and 6's in the back complemented by a pair of Alpine Type-R 12's in a professional-level Bandpass, fully amped to spec and so-on, but $$$$$$$.
So essentially, I run the 8-ohm subs in Parrallel, so the amp "sees" 4-ohms. 1200 watts @ 1 ohm, 600 @ 2, 300 @ 4, in theory. I believe the 1200 is a RMS, so that places the split power output at essentially 150x2 watts RMS. I know I can get the subs to clip, so I am capable of overpowering them, but the setup does run pretty cool.
Description
- 4 Ohm Rated.
45 Watts RMS
Sensitivity - 90dB
MAJOR KUDOS for the preservation of the OM goods.
