my new radiator
my new radiator
on monday i started something i was planning a long time ago, improve cooleing eficiency of my car, so i got a bigger radiator, and it is a two row unit, cooling has improved a lot and better yet i have enough room to put a secondary fan, next on my agenda is an oil cooler, by the way i get all my parts at the junk yard, so it is allways a budget install
ps. its raining right now, once it lets off a bit ill shoot some pics
i just got one from a friend that is going bigger, because of forced induction, its a canton unit with a sandwich adapter for a 4ag an it fits just have to make the oil lines and fit the cooler and se how it improves
pics tonight , at last it stopped raining
nice job with the radiator, it looks like it ifts in there nice. your air cleaner box looks different from any other tercel. mine only has one post in the middle of the lid where you put the wing nut. it looks like yours has two post. did you do a mod to your air box?
Daily Driver:
1988 Toyota Tercel SR5 4WD
3AC 2BBl Downdraft Carb
Project Car:
1993 Honda Del Sol Si
D16Z6 Head/Block
D16A1 Pistons (C/R 12.3:1)
Project Car:
D16Z6 Head/Block
It looks like a strut tower stiffener of some type. Apparently that is an option a number of Japanese automakers (and possibly those of other nations as well) offer nowadays. I remember looking at Element and Xb sales brochures a while back and noting that.
I guess it is something he needs in racing, but not something essential for street use?
its a strut tower brace, but its home made, mine got stolen i hada a cusco unit for a ae86 brough it from japan, but one time i went to get the car aligned i was stolen and nobody could be made responsible, so i bent a tube and welded here and there and got a strut bar for autocrossing
the rad meassurements i will post in a bit
It stiffens the frame in the front SIGNIFICANTLY. They offer the same things for the rear shock mounts. Those 2 things alone are significant stiffeners of the frame in their own rights. I think that a system that linked a forward strut tower brace to a center rollbar-type setup to a rear crosstower type brace would make our cars rock-solid. Help handling significantly. Even absorb some of the torque from a more powerful engine preventing stress-fractures in the frame. Though one that went up to the rad-support, to the strut towers, across the cab under the dash, up across/over just behind the front seats as a rollbar, over to the rear shock-mounts, then across/over the far back, against the hatch would allow us over 300 horsies methinks, solong as it had the proper subframe-support network. You could even create custom mounts for, say, a Ford 9-inch rear axle. Or a front solid-axle setup. Or for a more sporty A-frame front independant suspension, as on Subies if memory serves properly. Would make it easier to lower, thereby increasing handling even more. Would create mounting points for a lower full-length bellypan, further increasing aerodynamics and thereby fuel economy, high-speed handling, and top-speed...
lol
lol
