84 Tercel $700 central Florida. Bad front diff and trans
Manspaz
My tercel:: 1984 4wd Tercel
Post by Manspaz »
Well finally got her running great. Pulled her into the shop and the in park wouldn’t keep the car from rolling forward or back weird. Cleaned the carb up reinstalled and started right up. Got up to temp and hopped in to take a run around the block. Bad grinding. No movement. After some phone calls almost positive it’s the parking brake pin fell off inside the transmission. My loss your gain. Super clean car. Runs great. Has brand new starter. Drivers seat has a few little wear tears. Super clean. A little mildew on head rests. The body definitely has some rust for sure. Undercarriage is great rust free. Perfect for an engine swap, or interior swap. All windows work(a bit gummy from lack of use) $700 come and get it. Call or text 386-748-1540. Located Volusia county Florida.
