Do you know if...
French Vince
Do you know if...
Post by French Vince »
I am wondering if this wheels can be put on a 4WD Tercel. They're from Celica-Supra MkII.
Thanks for replying and sorry for my enghish. :wink:
MootsMan
Post by MootsMan »
the pattern of the bolt holes looks correct. I believe the measurement is 4 x 100mm. That is a pretty cool looking wheel. Was it only on European models ??
T-Bone
Post by T-Bone »
those rims look sweet. if the lugs line up make sure that the hole in the center where the hub goes in fits snug too. if its not that can snap off lugs.
Daily Driver:
1988 Toyota Tercel SR5 4WD
3AC 2BBl Downdraft Carb
Project Car:
1993 Honda Del Sol Si
D16Z6 Head/Block
D16A1 Pistons (C/R 12.3:1)
Gasoline Fumes
Post by Gasoline Fumes »
We had those wheels in the US too. I'm not 100% sure, but I think they are a 4 x 4.5 inch (114.3 mm) bolt pattern and will not fit a Tercel. :(
terceldude
French Vince.
Post by terceldude »
Yes it can. They both have a 4Lug x 100mm pattern. The only thing different is that this wheel is a 14x7" size. It is a Double 4-Spoke Rim. Go for it. Put it on and show us your pictures of it on the Tercel. Later :D
K-Business
dcn
My tercel:: 1987 4WD SR5 Wagon
Post by dcn »
Heh! My Dad's got those on his '76 Celica. Polished too, just like that! Neat!
Metallic Blue '87 4WD SR5
French Vince
They can be found on american models too.
I Have seen some classic celica (1970-1977) with, but never a Tercel.
I'have been confirmed taht they can't be put on a tercel because they are not in 4x100 but in 4x114.3.
Thanks for all and sorry for my miserable enghish.
20vtercel
Post by 20vtercel »
Those will not fit. they are 4.5" bolt pattern.
If you are lucky to find a newer rendition of them aka mini supra's which are 13x5.5" they come in both 4x100 and 4x114.3.
Look on the back of the rim. One of the spokes will have the specs.
Gasoline Fumes
French Vince wrote:Thanks for all and sorry for my miserable enghish.
Your English is pretty good, I understand everything. :D
Mac
Post by Mac »
the 4X100 version of those wheels would look awsome on a tercel, i'm going to put them on one day.
i found a set for $200 once at a junk yard, but i didn't jump on it, wish i did though!
terceldude
French Vince: Your Wheels.
Obviously, French Vince, you were misinformed. See here on bolt sizes:
http://www.geocities.com/MotorCity/Pit/ ... terns.html
This might help as well:
http://www.wheelcollision.com/toy3.htm
I know the wheels will fit. I saw some MR2 wheels put on a 4wd Tercel.
If you still have doubts, please drill the sides of the holes a little more and then they shall fit right then and there. Or, if that isn't a good method, have a custom wheel manufacturer manufacture the identical copies of those Celica Supra MKII wheels but in a 4x100mm bolt pattern.
K-Business
And pray, terceldude, what would the casual fabrication of custom wheels cost?
Possibly more than a Tercel is worth - do you think?
Perchance really ovalizing the holes will help in fitting? *
I think I saw some Minilites on a Bigfoot once...
* EDIT - This was tongue-in-cheek...
GTSSportCoupe
Post by GTSSportCoupe »
The most common Supra/Celica wheels are 4 x 114.3mm and will NOT fit on the Tercel. (As was mentioned above by 20Valve and a couple others).
Current:
91 LJ78 Landcruiser EX5
95 A32 Maxima SE
Former:
87 AW11 MR2 Smallport 4AGZE
93 Taurus SHO ATX
86 AL25 SR5 6spd 4wd
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
Dryfry
Post by Dryfry »
Also don't even think about drilling out ovalising the wheels to fit your car as that would weaken them and very well break as you are driving and you would die.
Best to have a look at some MR2 wheels to put on your Tercel.
What I've got 1986 Tercel 4wd wagon....Paint code 4G8 with brown interior.
Fitted with the Big Block 4A
Typrus
Post by Typrus »
Wow, thats sad.
I cross-set a Cressida's rims on a MKII Celi-Su and they fit. I then proceeded to BUY the Cressida rims, having been told the Cel-Su's would fit, and therefore the Cress's would fit. I jacked the car up, removed the steelies, and... COULD NOT GET THE CRESS's ON! They would not fit! 4.5" spec, not the 100x4!
So DO NOT believe that they will.
And I'm supposing you did the same thing as me Vince. As such, we have from experience the fact that they won't fit.
Turning the holes into ovals? Wow.. That is a VERY stupid thought. Look man, you can't expect to put an exaggeration of a weak spot into something that sees thousands of pounds of down, sideways, diagonal, and rotational force.
I'm not trying to insult you man, but that really was not well thought-out.
