Battery light wont go out but battery is charging
Leo Johannes
My tercel:: 1985 toyota tercel 4wd wagon. I have done zero modifications exept repairing some rust
Post by Leo Johannes »
My tercels battery light won’t go out but my battery is charging. I can find nothing wrong with the charging the battery ans alternator is new. Could it maybe be the ic regulator?
Paul
Re: Battery light wont go out but battery is charging
Post by Paul »
Check the battery voltage while it's running at idle in neutral. If its above 15 volts, the light can come on to warn you that the battery is suffering.
Leo Johannes
That ia not the problem, it began to light wgen the alternator and ic regulator broke but after changing those it is still on
What is an IC regulator?
There are two types of alternators for these cars: internally and externally regulated. Most of them are internally regulated. I have heard of people accidentally putting in the wrong type of alternator and having problems from that. Could that be a possibility here?
Esaus
My tercel:: 86 Tercel 1.5 Europe
Post by Esaus »
It could be a fault in the circuit. Ive had other toyotas including my tercel have issues with the lights not working properly and what not. I replaced a alternator and the voltage regulator and the issue still persisted. The new voltage regulator was broken, when i put in the original one it worked again! Toyotas of these years have issues where the alternator circuit might be connected to other areas. One issue I had was that the headlighs would stay on with the regulator plugged in.
1987 Toyota Corolla Dlx hatchback, 250000km Sold =(
1988 Toyota Corolla touring 4wd, estate restored!
1973 VW T2 Partybus!
1964 Heinkel Trojan, planned restoration
1963 Triumph Herald, currently under restoration.
