86 Tercel SR5 in Connecticut for sale
Ls1sx
My tercel:: 86 SR5
Post by Ls1sx »
This is my 86 Tercel SR5 4wd manual 5 speed with the creeper low gear. 224k miles
The car has mainly lived in Colorado , I just drove her back last October to CT flawlessly. Gets average 30mpg. If you drive easy she will get in the low 40s
I went completely through the car in the spring of 2022 at 204k
Parts included:
Engine: Timing belt, front and rear crank seal, valve cover gasket, fuel pump, ignition wires, cap, rotor, water pump, Belts, Oil pan gasket, upgraded 3 core aluminum radiator, fuel and air filter . vacuum advanced diaphragm, clutch kit
Body: Front and rear brake hoses , Rear wheel cylinder, front right wheel bearing, front kyb shocks, rear shocks, rotors, pads , front Cv axels, Rear axel seals,
All of the Transmission seals
I have a spare new ignition coil and transmission mount.
Just changed rear differential fluid, transmission oil, spark plugs, front pads, and steering rack boots
There is two spots of rust, they are on the bottom of the rear door jams on each side. The front sway bar bushings are worn, windshield is cracked
$4500 obo
lparisot
Re: 86 Tercel SR5 in Connecticut for sale
Post by lparisot »
Hey! I’m moving home to Connecticut at the end of June and I’m looking to buy my first 4wd Tercel. Is this still available?
edzomatic56
My tercel:: 1983 Sr5 4x4
Post by edzomatic56 »
Hi,
I would be interested in coming to look at the tercel at your convenience if still available. Im up in Scituate Ma. You can also text me on my cell at 415 407 7082. Thanks, Ed MacCormack
kilroywashere
My tercel:: Looking to buy.
Post by kilroywashere »
If this is still available I'd be very interested. Will PM a phone number. Thanks.
