3A-U motor.
Idago
My tercel:: 84, lifted, Weber, low miles 475,000...
3A-U motor.
Post by Idago »
I bought tercel parts car that has a 3A-U motor. It spins over and probably is serviceable. Apparently a Japanese version. Probably a replacement motor. Online research says it's 83 HP but still a 1.5 liter. Does anyone know more about this motor? I plan to swap it in to a tercel soon and get it running again. I will just use the long block and my own peripherals.
Re: 3A-U motor.
I am very confident it is not 83 hp. That is likely a typo, or maybe someone trolling. It's possible the 'swirl' engine was 1 or 2 hp higher than the regular 62 hp 3a but by and large, 3a's are only 62 hp.
Mark
Re: 3A-U motor.
Post by Mark »
According to Wikipedia, there are several versions of the 3A engine, all with different horsepower at different rpms and different torques. I always assumed that the higher horsepower ones lacked the horsepower-killing emissions requirements of the North American ones, but maybe they have different camshafts for different torque profiles or something. https://en.wikipedia.org/wiki/Toyota_A_engine
Nordical25
My tercel:: 1x86, 2x87
Re: 3A-U motor.
Post by Nordical25 »
3A-U motors can have also different carbs & intake manifolds, which affect also engine power.
I have also discovered that European and American Tercels have different weights and springs in distributor. I wonder if distributor internals can affect also power.
Re: 3A-U motor.
most of the JDM 3a engines had a duel SU carb set up, and I suspect a different cam profile as well as totally different emissions system (not as restrictive). I would love to get my hands on the JDM duel carb and manifold set up.
I am just about done chasing my tail with the USDM emissions/fuel systems. as mine age, more and more parts stop working correctly. some I can remove or by pass, but some must be working properly for the stock USDM carbs to run properly. Although when working properly I like the factory set up, it is economical and fairly reliable, but my whole fuel/emission system parts are coming up on about 400k miles, and 40 years old. I keep replacing the parts I can get or have spares for, but many of the parts are NLA, and these cars are getting rare at the wrecking yard these days. I likely will be doing a full EGR delete this weekend, and I will have to get the choke working properly before this winter, I have it rigged to stay open all the time now (cold starts are a bit annoying, but runs after warmed up).
I keep thinking there must be a better fuel system to switch to that is not too costly, has good drivablty and gets good economy. the after market EFI kits are just too costly, and none I have seen can are plug and play. all take a lot of fine tuning.
José Tara
My tercel:: 4wd 1984
Re: 3A-U motor.
Post by José Tara »
Busco información sobre este motor, lo tengo en mi tercel 84’, es timón cambiado, se supone que viene de Japón directamente, es de transmisión automática, e tenido problemas con el distribuidor, primero con la bobina y luego con el módulo.
Saludos desde Tacna-Perú
terceldude
Re: 3A-U motor.
Post by terceldude »
dlb wrote: Fri Apr 28, 2023 8:09 am I am very confident it is not 83 hp. That is likely a typo, or maybe someone trolling. It's possible the 'swirl' engine was 1 or 2 hp higher than the regular 62 hp 3a but by and large, 3a's are only 62 hp.
Actually that is wrong. 1982-84 was 83 hp and 84-88 was 85. the 3ASU was 90. Our 3AC was 62
K-Business
