The last week or two, out of order:
Getting things together, it barely fits width wise on the tilta lift. Its so narrow it wants to fall in between.
A weldnut internal to the rear subframe broke off for the rear sway bar mount. I used a rivnut same bolt size to fix.
Front driver side suspension corner.
Tanks rough fit, before cap finishing.
Cap of windshield washer fluid laser etched and color filled. Not pictured is the cap for the coolant overflow
Company who makes AFR, required me to cut the new/faulty o2 before getting a "one time" replacement, as the company claims to not offer replacement sensors even if new/dead for free under any warranty, must purchase.
Underside of the air-con/heat climate control module thing. The 4x cables attach here on this end. The blend-door was filthy, and 3x of the cables needed some good cleaning.
Front caliper banjo bolts were alarmingly short, so ordered some aluminum hex from mcmaster and got these turned and laser etched.
I found this plug under the steering column that went no where. It contained a ground AND ignition 12v, both got de-pinned and just a shrinky-spade connector setup to the afr gauge.
Electrical and vac lines cleaned up. The guide here on the forum
viewtopic.php?t=7442helped immensely. It is the early Tercel 1AC engine, however vatozone had the PCV and gasket for an 83 corolla, which seems to be same same. Toyota originally used a nice curved vacuum line off the PCV, but they were limited use and seem unobtainable.
