Aisan Secondary Diaphram
Richard164
My tercel:: Looking at 86 4WD DX
Post by Richard164 »
I needed a Secondary Diaphram for my Aisan carb. I had a lot of trouble finding it, so wanted to share where I finally found it.
First, there seems to be at least 2 different diaphrams. In Roberts excellent carburetor rebuild video, the rod on his Secondary Diaphram is straight. I believe that one can be purchased from NAPA, part number CRB 24093.
My carb, tag # (21100) 15280 has a bent rod. I contacted 5 places. 4 told me it was no longer available. However, a tech at Walker Products dug deep into it and found it.
Walker part number 1314F.
Pic is of the one that came off my carb
Re: Aisan Secondary Diaphram
Thanks for sharing the part number.
MrWrench
Post by MrWrench »
Great find! Thanks for sharing the part number.
1983 AV-II Sprinter Carib.
SirFoxx
Post by SirFoxx »
Richard164 wrote: Mon Apr 03, 2023 9:27 pm I needed a Secondary Diaphram for my Aisan carb. I had a lot of trouble finding it, so wanted to share where I finally found it.
were you able to order this part? all my diaphrams i believe are shot, looking like they have expanded over the years and are unable to pull the secondary open.
what led you to the conclusion that your secondary diaphragm was bad?
viewtopic.php?t=16285
1982 4dr Tercel (RIP)
