Automatic radiator in a manual car?
- My tercel:: 1985 Toyota Tercel 4wd Sr5, Fed emission but no cat converter. Manual transmission, with air conditioning.
Will an automatic transmission radiator be safe to put into a manual transmission equipped tercel?
Re: Automatic radiator in a manual car?
What's the difference between the two radiators? Manual vs Automatic? Partsgeek seems to think it matters but I don't buy it.
- Mark
The automatic ones have a section on the bottom that is a transmission fluid cooler. It has small inlet and outlet pipes for hoses from the trans. If that is the only difference (eg, mounting points are the same), these pipes can just be left disconnected and it should be fine.
