I dont want her going to the yard. I have to move off property is is on In garberviille Ca. T
Registration good until Dec
You can have towed with your triple a AAA
bc tags still good
Please msg ASAP
Sadly my 1983 tercel sr5 transaxle is done, and I do not have time or expertise to continue on with her.
It started when the passenger CV axle busted on a dirt road. I thought it was an easy fix, not too concerned when I saw some metal shavings in the transaxle fluid as I drained before installing new CV Axles, axle seals, inner and outer tie ROds for the driver and passenger,
but when I went to Drive after it was all in, I heard a terrible thud, and I will not engage properly. My buddy thinks its the spider gear, but at the very least the transaxle needs a tear down. I wish I had time, space and money, but I got to move on.
The tercel will need to be towed. It is located in GARBERVILLE, CA up country roads.
Some stats
1983 Toyota Tercel SR5
Sunroof (has never worked and was stuck shut when I bought it)
Sunroof motor does work ( you can hear it, but it does not move sunroof)
Sweet Plaid interior with OH SHOOT handles on the front head rest
Inclineometer (works perfect)
It has A/C but needs a recharge ( I roll my windows down)
heater works great
extra low granny ( 4wd works great and will miss it the most)
New clutch around 140xxx miles (done at Toyota 4wd shop)
brakes are good
engine is strong
new spark plugs and wires
13in PIZZA CUTTERS
all doors open and shut, all electrical works as it should. Paint was done by previous owner, but he failed to clear coat, so fading.
replaced seatbelt buckles (old one broken and would not stay erect) you can see old one on the floor behind drivers seat
low miles 153,985
new California Catalytic converter in 2018
Registration good until December 2022
Ive own since 2018
SOOO much fun to drive.
looking to get it a new home
1983TercelSR5 good looks, bad transaxel =-(GONE)
- My tercel:: 1983
Last edited by mysideconquest on Thu Nov 03, 2022 2:44 pm, edited 3 times in total.
- My tercel:: 1983
Re: 1983TercelSR5 good looks, bad transaxel =-( $2500
more pics
The old wood and oil stain is my attempt to show
I replace the old warn out spare tire cover
with 3 pieces of inch think wood. One main center piece and two unique
cut pieces that fit behind their the fender on each side.
It also has the full size spare,
and newish tires (less than 10,xxx)
- Nordical25
- My tercel:: 1x86, 2x87
That car looks low rust one so hopefully your car will find a new owner.
- garyfish
Re: 1983TercelSR5 good looks, bad transaxel =-( FREEEEE)
Just now saw this post. Is this wagon still available? I live about 1.5 hours away from Garberville, on the coast near Petrolia.
Sending you a PM now.
