I am converting my 83 t4wd back to factory carb
For fuel economy and because i live in nw montana and weber doesnt do well in deep freeze or 100 plus which are both common here. I have 83 parts car with factory carb to put all the pieces back.
Wondering what are biggest thinks to replace after engine has been modd for weber? Or any other tips.
Thanks for any info!
Converting back to factory carb
Re: Converting back to factory carb
Do you still have all the emissions components that go with the stock carb? If not, they should be easy to find -- lots of people swap to Weber's and throw out all the emissions stuff. I find the stock carbs work best with all that stuff in place and working properly.
- Mattel
Agree with David. Take heaps of photos of your stock parts car. When I went back to factory carb I put one car next to another and took one hose off at a time and replaced it in the same place on the swapped car.
